US Amps USA-200 Amplifier
I’m testing ohms between 4 & 8 then 13 & 9.
The attached relay is what you have.
The relay will have the common contacts read 0 ohms to the top contacts with no coil voltage.
When you have 24v across the coil, the common contacts should be pulled down and read 0 ohms to the bottom contacts.
If you relay isn't doing this, it may be defective.
