US Amps - Power Supply
2.2v at the led pads when bench supply is at 14.4v.
So assuming 494 pin 3 would turn off the IC off at 3.3 volts - what can I do to turn that led on when pin 3 reaches 3.3 volts. I tried increasing R34 but that results in a gradual turn on not a switched on and off which is what I need.
Or, I just disconnect it and say, "your amp works fine but your protection led is not going to work."
Desolder the striped end of D11 and confirm that the collector of Q30 goes to very near 0v.
Desolder one terminal of R56 and measure the resistance across the thermistor. What's the value.
Reconnect R56 and heat the thermistor to confirm that the voltage on its low-voltage leg (connected to R56) rises as it's heated.
Stays at 5v
103K
Yes voltage increases with heat
Confirm that R57 is within tolerance.
C33 may be exhibiting dielectric absorption. Replace it and confirm that the voltage on the collector of C30 not longer remains at 5v.
What's the DC voltage on the terminal of the thermistor that varies with temperature (while it's at room temperature).
