Hi Guys,
Thanks for your patience!
Finally, the first shipment of the enclosure were received today!
I'll contact you based on the order of ordering time.
The gross weight is about 51 lbs per pairs.
Will there be another opportunity to get in on this buy or another one like it?
Thank you,
-David
Thank you,
-David
Hi JR,
Not sure I understood your reply regarding a follow-up order for the new Amp cases. I like the reciently attached pictures with the rear connectors at the top rather than along the side.
When would this case be available to order?
Thanks!
-David
Thanks!
-David
