Upgrading Vintage Dunlavys Issue
I've got a vintage pair of Dunlavy SC-III-A's and an S-I.CC from 2000 that I'm looking at upgrading the crossovers. My problem is that towards the end Dunlavy started recessing their backplates to be incredibly tight-fitting (see picture). Does anyone have any techniques beyond trying to push out from inside the speaker (not practical due to cabinet construction) without marring the finish?
TIA, Mark
I whole heartily agree that John knew what he was doing. I also know that there are sandcast resisters in the crossover and Solen non-bypassed caps. I am not attempting to redesign simply use higher quality parts that were not used 20 years ago.
Use a short large diameter self tapper screw (to bite into the metal plate) and then use a claw hammer levered against a piece of suitable timber (to protect the surface of the cabinet)
And if it has a sealing gasket of some kind holding it in place, you might have to use a hair dryer to heat the plate, to soften the gasket to help facilitate removal.
good luck
Unless you can do impulse response tests, swapping different parts in a seemingly upgrade on your part, you might shift parameters enough to shift what he strived hard for.
I do have the measurement equipment to ensure that I would not be changing values and these the response tests. While I am new to being a member of Audio Circle, I been in this hobby for over 40 years including stints as a service tech and audio circuit designer. Therefore, I am not concerned about that though appreciate the warning.
