Hello everyone ... I have this integrated Sonic Frontiers and I want to upgrade it ... apart from the tubes ... I would like to change the capacitors that go to the EL34 ... these are .1 uf ... what happens if I upload them to .22uf? Would it be worth putting hexfred diodes on the power source? Thank you for your comments, greetings
What diodes are in the unit now? If 1 A. 1N4007s are in use, the direct replacement UF4007 is a nice, and "idiot resistant", upgrade. The 1N5408/UF5408 is the 3 A. analog.
As with diodes, cap. changes require thought about both mechanical and electrical factors.
The schematic would definitely help.
How to attach images to your posts.
