Upgrade my LP12 or move on?
Hi all, first post on the forum. Joined a month ago and have been enjoying reading many posts; fascinating stuff!
I have owned a Linn LP12 a few years and did a few repairs and upgrades earlier this year - Cirkus bearing, Armageddon clone, Rega RB202 and a DIY aluminium subchassis. It sounds good but Im not entirely happy with it; so the quest for upgrades continues. The next step was to change the tonearm and make another (mk2) subchassis.
The new tonearm is an Audiomods series 6. It arrived in the post today and looks great!
Reason for this post is to check with guys with more experience whether I am better at this stage pausing and switching to another platform and move on from the LP12. Im trying to get to a point where I have a very good TT I can settle down with and enjoy. Can I get better results with a different unit, for similar cost and effort? I had not heard of Lenko before joining this forum but see that gets good reviews. Is it worth moving on to a GL75 or some other option? I don't want to spend thousands, so a very good new TT is not an option. Also the Mrs likes the retro look (its the only aspect of my hifi she likes!).
It would be good to get some suggestions so I can research further. Im ok spending time and effort upgrading an older unit diy. I have a woodworking workshop and a metal lathe too. Regards, Mark.
It's not easy to beat well sorted LP12 contrary to what you may have read.
I also think that Nagaoka MP 110 may be a little bottleneck to LP12 performance. What is it that you are not happy with your sound now ? How about the rest of your audio chain ? Phono preamp?
Yes fully accept the cartridge needs to be better. The Nagaoka was a temporary move and I will spend a lot more, maybe next year. The phono is built into the Brystom preamp as a factory option; MM and MC compatible.
The sound gets a bit muddled in complex passages. I have some work to do to tune the Armageddon and may try some of the other motor drive options, or even dc. I hope the new tonearm will be a good improvement too.
I'm all ears about clever spending regarding cartridges. One can take a risk and buy used carts and it's what I have done with success more or less but buying a new cartridge for $120 or $200 is kind of waste of money to me. Better to buy a used cart from a reputable maker. With passing years I kind of lost my belief in giant killers or super deals. One just has to spend some basic amount of money to achieve a basic amount of satisfaction .
Resolving complex passages is not an easy task for any vinyl rig. Better cartridge and that new audiomod tonearm should help.
Used carts are not a risk when you have a friendly Russian to fix them! Although I should have just had my Benz woody retipped when it wore out I've ended up with half a dozen brilliant (and unique) cartridges, none of which cost me more than a few hundred. I got a bit carried away and needed to sell a few in the end. Currently listening to an Ortofon Rondo with the Cantilever and stylus off an AT155LC (Be) and rather enjoying it.
You need to make the jump to LOMC, as your preamp is compatible. Everything I've read about the Audiomods arm suggests it's very good, so I wouldn't be looking at something else. I've been running an old AT33PTG for a while, it's definitely a very good budget MC.
A Hercules for the motor PS is another option.
jeff
Thanks for the comments it seems keeping the LP12 is the consensus.
Where are the pics???
I don't think I can post pics yet. I made the subchassis from two 2mm aluminium sheets spaced apart with some turned parts for the spring, bearing and tonearm mount. The spacers are spigotted in and glued and the 8mm gap between the sheets filled with PU foam. Its stiff and light. Maybe not as good as a Keel but im happy at £20 for materials 🙂 I also moved the spring nearest the arm to balance loads on the springs better. All this was designed in CAD - I reversed engineered the turntable in Creo.
Im going to make another subchassis for the Audiomods tonearm. There are some lessons learned from the first and it can be designed to mount the new arm perfectly.
