UPC1237 DIP IC
There was another thread on the same subject a couple of months ago. I don't think anyone managed to find a source of DIP, only SIP, although I seem to remember a data sheet that said DIP or SIP versions.
Have you checked the amp schematic versus SIP data sheet? If it is just a package change, chances are it might be ok.
Edit: this one upc1237C-A?!!
The only 1 that will fit is DIP 8, 4 legs on each side. Rotel some how doesn't have the part. The link you supplied is the UPC1237C DIP, would this work in place of the UPC1237 DIP? The part is only $1.80 with a $25 minimum.
