Up2stream and Wondom Jab 2 (Wifi & Bluetooth)
Hi
I am new to DIY and as a first project I am trying to build wireless wifi audio using Up2Stream wifi module (by Arylic), WONDOM JAB2 (2x50W) and JAB3 (1x100W).
However, I don't know how to make connections with wifi and bluetooth mutually exclusive. When I connect with wifi and try to stream the music, bluetooth connection should automatically be disabled.
Secondly, how to I connect 3.5mm input too and all three inputs mutually exclusive.
Appreciate any help.
I have not tried this, and this may be too late of a reply, but you could cut the cables running to pins 1 and 6 on the J5, which is the jab3 input from the jab2 bluetooth, then run the that to a dp3t switch, along with the bluetooth output lines and your other sources, giving you mutually exclusive input for all three.
