Unusual behaveour of Marantz
Does anybody have a simmilar problem with Marantz PM7200 output section.
Everything is working fine until I try to switch on loudspeaker ouputs (No speaker connected) , than the quiescent current on both channels rise and i must turn of the output binding posts before mad heat up.
I dont know what can go wrong by switchin on only output relays:hot: .
this only happends when class A mode is used. Help please. I am pretty pist off with that problem😡 .
Graham Maynard said:
Hi Gasho,
This amplifier is known to run hot in class-A - it is meant to.
One friend fried a DAC that he had sitting on top !
Cheers ....... Graham.
Indeed. And, if the heatsinks get too hot to touch more than a few seconds, they may still be less than 50 degrees Celcius. We don't really know what HOT means anymore😉
Jan Didden
I understan that class A means hot heatsink , but this is too much . When I measure the voltage across emiter resistors (0.18 ohm) it is too high , about 490mV:hot: . That is not OK.
This only happends when I switch on the output relay for loudspeaker.
Somethig is very wrong here. I must run some tests to locate a problem wich is very srange.:bawling:
Hi Gasho,
I'd love to hear what you think of the sound of this reasonably priced amplifier.
Reviews say that it has reasonable power, a decent phono input stage and useful pre-amplifier options.
Is it a good basic amp, and has removing the output choke improved it ??
Cheers ......... Graham.
