unmarked IC, Bass Habit 3100.1DF
I need help identifying this ic marked c2 right side of the black caps. i think it a UCC27524 or a UCC2742 anyone know?
It seems to be a common issue with this board that the output fets blows and takes the irs20957s with it.
forgot to upload the pic😳
i seem to have some trouble with one of the irs20957s, i have no ho o lo output on pin 14/10, pin 1 have 10v, pin 11 15v, pin 3 is a nice pwm signal, ive checked all pins between the two irs20957 and do not see any difference more than a scrambled ho signal on the working chip, traces for the gate drive are lifted on both ics.
both ics are replaced numerous times.
Might help if you had a better pic, and if you would sketch out a schematic of where the leads of that mystery IC go. If its a low cost board, it might only be two layers. If so, its pretty easy to trace out connections to help figure out the circuit function.
have finally made some progress, i changed both irs20957 and as soon as i did lo and ho disappeared on both 20957,
pin 1 10v
pin 3, nice pwm
pin 4 0v
pin 10 0v
pin 11 15v
pin 13 12v
pin 14 0v
pin 15 24v
referenced to pin 9
pin 2 was 0v which should be over 5v as i understand
lifted a 120k resistor (R155) which goes to pin 17 on mcu and then to a 150k resistor and a cap in parallel to ground
lifted a transistor (Q42) which connects to pin 20 on mcu
now i have voltage on csd and lo and ho works
what could be causing the mcu to shutdown the ics?
