Does anyone have a good source for perforated steel mounting plates for amp innards? I'm looking for something about 280 by 280 mm, but I can always cut to fit.
I'm not sure what you are looking for. Try www.mcnichols.com, they have locations throughout the US. E
I need something similar to the optional steel mounting plates offered for the full sized DIY chassis from Modushop. I suppose I could order one of those and cut it, but shipping would be prohibitive.
DiyAudio might offer those when they get chassis back in stock. Check with them.
https://www.mcnichols.com/search/perforated-metal/round-hole
McMaster-Carr has perforated sheets in steel and aluminum. Looks like the smallest is 24" x 24".
https://www.mcmaster.com/products/~/construction~perforated/?s=steel+perforated+sheets
jeff
jeff
I'm loath to recommend Amazon but they have something you might be able to use. Not cheap.
Perforated Sheet
Perforated Sheet
I build my own amp cases and I find that Metal Supermarkets can provide aluminum in all shapes custom cut for reasonable prices. Luckily, there is one close enough to me so I can pick it up from their shop. I have bought plate and perforated plates and their cutting service is very precise and accurate. I purchase angle bulk and cut them myself.
- Design & Build
- Parts
- Universal mounting plate
