Unipolar vs complementary input stage
john curl said:
For the record, fellow engineers: The S/N of the JC-1 amplifier has nothing to do with the input topology. It has to do with making the amplifier able to easily accept either single ended or balanced drive with a minimum of added active components, YET have significant input common mode rejection.
That's easily accomplished with just a couple lengths of wire and some nickel. No active components necessary. 😀
Not only would you have better common-mode rejection than your active balanced input, you'd also have similarly high common mode rejection even with single-ended sources.
And the icing on the cake would be galvanic isolation which would save people ground loop headaches.
se
jcx said:
Bob,
do you see any reason today to include R3,10?
The increased gain applied as global feedback throughout the audio band decreases all distortion products including Otala's PIM
No, I see no need to include R3 and R10. That is why I prefaced my remark with something like, "for those who prefer this approach".
These resistors were not included in my original MOSFET power amplifier. I showed the approach using R3 and R10 to address the concern about lack of open loop bandwidth expressed by John Curl.
You are exactly right about the increased gain applied as global feedback decreasing all distortion products.
Bob
Fellow designers, many of you are using versions of SPICE that I am not personally familiar. It might be that you can't separate the noise contributions to the total output noise in a complete circuit. Can you do this with the SPICE available today to most of us? Or do we have to buy the PROFESSIONAL version of SPICE to get this added benefit?
john curl said:
We invented the complementary differential input stage here in the USA in the 1960's. American engineers had easy access of complementary small signal devices, even as matched pairs, in the late 1960's through Motorola and other manufacturers.
In 1972, I showed Bob Stuart of Meridian the complementary differential transistor pair, and he started to use it immediately.
Hi John,
Who is "we"?
It is my understanding that Jim Bonjiorno conceived the complementary differential input pair while he was at Dynaco, put it into first commercial product in the SAE XXXIB in early 1973, and subsequently published it in PE as the Ampzilla in 1974.
Can you point to any commercial product that predates those?
Perhaps Charles Hansen can shed some light on this, as he seems very interested in audio history.
Is it possible that you are only laying claim to the implementation with JFETs that has the floating tails?
Bob
No, Borgorino did not invent the complementary differential input stage when he was as Dyna, to the best of my understanding. In fact, he offered the Dyna circuit to Southwest Technical Products, and learned about it from the designer there. This is what I have been told in detail.
I designed the complementary differential transistor input 39 years ago, and my old friend Jon Iverson, designed it at the same time or even earlier.
We did NOT publish the circuits for good reason, at the time. In 1969, I did have a full complemetary symmetry balanced bridge, current out power amplifier designed and running in the Ampex Research Department that was capable of several thousand watts DC output.
With circuits like these, it is certainly possible that multiple people came up with it, independently. But the first person who comes up with it independently and makes a commercial product out of it, or publishes a paper on it, is generally credited with it.
Many of us engineers, at one time or another, have had this sort of thing happen to them. That's life. You could invent Cold Fusion in your lab and not tell anybody about it, and you would not get credit for it. If you invent something and keep it under your hat, you don't get to claim it - that's just the way the world works.
SWTP was Dan Meyer, and as far as I know, he did not have any product with that circuit in it, at least in that time frame, and certainly not the Universal Tiger.
Bob
For example, I had to add a 7.15K ohm resistor at the (+) input in order to balance the gain of the inputs of the amp, so that common mode rejection is significant.
Other options would have added more active devices in series with the signal.
I spoke to Parasound yesterday about it. Perhaps, a future upgrade will incorporate a different approach, although no one has complained about it up to this time. You must remember, that we do not usually amplify high sensitivity loudspeakers with a 400W power amp. A small power amp of 50W should be more appropriate for horn speakers, etc.
The problem with active loads will not be very important with power amps, BUT it would be very important for a phono or microphone input stage.
Doesn't anyone know about this? Doesn't SPICE evaluate this.
I know that I saw the SPICE analysis of the 741 back in 1971, and it showed it clearly. This was one of the FIRST times that I saw SPICE show a problem that was ignored by the designer.
Hi John,
My 108 dB in my 50 Watt amplifier is 20 dB better than the JC-1's S/N. 20 dB is a factor of 100 in power. If your amplifier was a 5000 Watt amplifier, your argument about speaker sensitivity might make sense.
The proof is in the pudding. My circuit cannot have much of a noise "problem" if it delivered 108 dB S/N, beating the very good Boulder amp by 3 dB.
I haven't made any claims about my circuit for use in a phono or mic preamp, as the discussion in this thread is about power amps. Although it might be very suitable and low in noise, I did not design it with that in mind.
Bob
Noise, per se, is rarely a problem in an amplifier unless you have pretty efficient speakers. Horn fans are more likely to have complaints about noise than other folks. My speakers are more modest--efficiency in the mid to upper 80s--and noise is just not that much of an issue to me. The same is true for most people.
A more subtle point is the interaction of noise with the music in somewhat the same manner as IM distortion, but since noise is generally so low in high fidelity amps it's not that much of an issue.
Now, if you want to talk noise, let's talk about phono stages for moving coil cartridges. That's a valid discussion.
Grey
john curl said:
Bob, please don't go crazy with this. You are not using the same circuit gain or features that the JC-1 has. It can be proven, even with SPICE that my circuit topology is slightly quieter than yours, all else being equal.
I don't think I'm the one going crazy with this, John. It is very simple: the proof is in the pudding. You assert that there must be a noise "problem" with the circuit, and yet that circuit delivers better S/N than most of the amplifiers ever reviewed by Stereophile. I do not rely on the mediocre noise performance of the JC-1 to make that point.
Until you or someone else goes to the trouble to make all else equal and simulate the two topologies for noise, I don't think that you can assert that one or the other is quieter. Now that you have SPICE up and running, why don't you give it a shot and let us know what you find?
Bob
