Amps is back up and running after C6 bit the dust and in setting everything up I pulled the meters out and spent some time making sure all is set and stable.
I have a few different 5U4G rectifiers and I noticed that the Raytheon has lower B+ voltage the the two RCA's, 248-250 vs. 282-286. In deciding to leave the lower volt rectifier in there I spent some time getting the bias set where it sounded the best. 32mA was the ticket.
If I decide to run one of the higher voltage rectifiers should I reduce bias? Hot hot is too hot? What about tube life?
I believe I understand the principal of bias just looking for the practical. I also have read Georges suggestion of where to bias a 45 amp in Tubes and Applications.
Why does suggested bias go down at higher voltages?
Thanks,
Walt
Thanks,
Walt
You may have read this already but I think it explains well how the tube dissipation and voltage don't always go up in line with each other.
Idle Current Biasing - Why 70 percent?
I can't say that I can follow it all but I am picking up bits and pieces of it.
I am just starting a SSE build so I'm trying to learn myself.
