Unbalanced Line Driver
I was just thinking about this earlier, is it this simple to make an unbalanced line driver? This should result in a 2X increase in voltage (say an input of 2V resulting in 4V) right? Do I need any other parts except for the cap to prevent the op amp from oscillating? What would be good op amps to use here, the standard NE5532, NE5534, Burr Browns, etc.?
Thanks.
Didn't ANYONE else make this mistake when they were learning about opamps? He's just trying to make a non-inverting opamp.
When they first teach you about inverting opamps you "pretend" the inputs are at the same voltage and then just sum currents and *poof* you have gain.
So the first logical step is to reverse the inputs and it should be noninverting... I mean.... they tell you after all that the + is the noninverting and the - is the inverting...
I thought everyone does this in school.... ok atleast I did 🙂
actually it's funny how if you use the simplification assumptions, it doesn't matter which terminal is + or - it still works out to be an inverting.
