Hi folks!
I am trying to learn to use SPL Copy software, but I get stuck on a strange problem. Cannot select Low Amplitute using mouse, line jumps up right after I click to lock it at lowest point. Same applies sometimes for Low Impedance, but I have managed get it to work moving lowest impedance line little up.
Only thing I have noticed: tried select "Auto-hide the taskbar" in taskbar properties, it started kinda work. Can small screen cause such a problem, or I did something wrong? My laptops screen resolution is 1366x768.
Thanks.
Thanks.
It may in fact be that your screen is too large (as odd as that may seem). I can't remember if it is splcopy or one of the other FRD tools but I know one of them has problems if the screen is too big. Try making the window a bit smaller and try again.
Tony.
Tony.
Tony.
Thank you Tony. Unfortunately my screen is small compare to modern computers. 😀
Hiding the Windows taskbar worked for me so far. But I will get back if something more strange happens.
Pretty sure one of them I ran into problems with a 1280 X 1024 screen size when window was maximized. But making the window smaller fixed it 🙂 but yes I run 2560 x 1440 on my main computer 😀
Tony.
Tony.
