Hello!
I am lookin' for an ultra-easy distortion effect to build. If you guys can help me I would love that coz I have tried to find in google, but couldnt find anything interesting. Plus I dont know too much, so I dont know exactly what is a good, working and easy schematic. So I basically have hard time to find. If you guys can help me that would be Awesome! 🙂 Thanks!
tschrama said:try 'proco rat' in google... simple but pretty good sounding guitar distortion effect...
Thank you! But that's the reason I ask it here: I heard that the schematics on the internet are sometimes not good and not working. That's why I ask if you guys can help me finding me a good working one.
As for the guy that gave that last schematic: Thanks alot! I will try that! 🙂
http://www.joness.com/gr300/proco.htm
you can forget the input and output buffer (BF245a and related components).. just straight in the opamp (cap, biased at 4.5Volt).. and striaght out to a 100K pot...... that's how I build them... higly recommended...
offcourse a tube schematic is a totally different game.. both sound and build-wise.. 250Volt on a stomp box is not recommended ......
PS
ultra simple, but doesn't sound halve as good as a rat..
http://www.joness.com/gr300/dod250.htm
PS
tschrama said:250Volt on a stomp box is not recommended ......![]()
I used 1/8" aluminum on mine, with the innards mounted on rubber grommets for shock absorbtion. All metal, of course, is grounded 😉
another CHEAP AND VERY EASY one to build that is jfet based and has a decent sound if you up the gain a little
http://www.till.com/articles/GuitarPreamp/
I have built it and it did work.
I did change a few things though
the 3M input resistor isn't present on my preamp design
the 51k resistor on the output has been changed toa 47k being that was the closest I had
you can change the drain resistor (2.2k) to change the gain of the amp up or down. larger resistor less gain, smaller resistor for more gain leading to distortion if you go low enough.
I haven't tried it yet, but I hear you can wire a digital inverter like an opamp to get a quick and easy distortion effect.
It's on my list of experiments.
http://www.runoffgroove.com/doubled.html
Not always easy to tame those inverter based circuits. Sometimes they sound like 1000 000 dollars but another day and setup your circuit just sucks
It would be advantageous to run the circuit off a Mains supply. Those Inverter-based circuits are really sensitive to battery voltage. Quite understandable, as the non-linear point sets in at a certain level below V+ (positive amplitude) and above 0V (negative amplitude). I built such a circuit with adjustable voltage - and there was only one usable setting for the supply voltage, AFAIK. A volt below this - and the thing sounded like ****.
I also seem to remember that those circuits should be built using an even number of inverters in the signal path, as distortion is not symmetrical. After 2, 4 or 6 inverting stages it's evened out.
Here's a site that has a lot different guitar distortion schematics, although some links are broken.
http://www.geofex.com/schemata.htm
If you wanna go ultrasimple, check this out:
http://home-wrecker.com/bazz.html
Much modding to be done. I put 2 in series, added some pots and changed some R and C values around.. grat fun and good overdrive to fuzz sounds
/Johan
/Johan
www.diystompboxes.com
Many distortion schematics out there
Check
www.runnoffgroove.com
www.tonepad.com
www.generalguitargadgets.com
home-wrecker.com
fuzzcentral.tripod.com
www.moosapotamus.com
www.smallbearelec.com
Check
www.tonepad.com
home-wrecker.com
easy distortion project
good day!
try http://www.j.philpott.com/effectronics/ this site will guide you for building a distortion.
actually, the schematic does work, the fact that i made one.
good luck!
good day!
good luck!
- Live Sound
- Instruments and Amps
- ultra simple distortion effect
