• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Ultra Low Noise JFETs from Texas Instruments
I think TI disclosed the 150 is the exact same die as the 2140, just pre-bonded for devices in parallel. The catch diode pins are a giveaway for that, too.
Interesting note from Interfet about crosstalk: https://www.interfet.com/jfet-application-notes/thermal-soic-8-package-jfets-at-interfet/
There actually could be some interference. Let's wait what TI has to say.
After comparing the datasheets, 150 and 2140 are slightly different. My first impression was that 150 is the same die with paralleled 2140 FETs... 😀
...and it confirms, that there is an internal "connection" that may make issues depending on the use and voltage levels of both Fets.
If you put the clamping terminals at AC grounds as recommended then that measly 1pF of additional stray capacitance is rendered ineffective. In a diff amp one might even bootstrap them.
Thermal (low frequency) coupling is the thing to watch with these monolithic dual JFETs.
Adopt the input stage of JFE-2140.
Reactions: Mr.Knackwurst
