Ultra-High performance OpAmp-based MOSFET Power Amp
Disabled Account
Joined 2005
Got you, didn't I?
Well, enclosed is a conceptual design of a power amp using an opamp front end.
I have always wanted to see how well they will perform and how different they are from discrete designs. so here is my attempt and your comments are welcome.
Two issues that I had to deal with in this design:
a) insufficient voltage gain for high power applications: opamps run off low rail voltages. to solve that problem, I had to add a voltage gain stage consisting of Q1/Q2 and associated resistors.
Rather than driving them from the base, I decided to drive them from their emitter so that I can apply nested feedbacks.
b) stability: to get this thing to stable, I have to introduce local feedback and global feedback. thus the nested feedback here.
One really good thing about this amplifier is its clipping behavior: it is really soft, :), un-SS like.
Also, most of the harmonies are 2nd and 3rd.
Now, the bad things:
a) significant phase shift: I haven't been able to find the cause of it. the amount of phase shift doesn't seem to change with the opamp used or mosfet's used.
b) relatively large thd: usually in the 1-1.5% range, unless you dial up the bias current to over 250ma.
Please let me know what you think of it and how you would improve it.
Disabled Account
Joined 2005
on the issue of distortion, you can reduce it by a) running the driver stage at high current (how about 100ma?) and b) introducing some negative feedback here by using connecting resistors between base and collector of Q4/Q5. I used two 33k resistors there and it substantially reduced thd.
Hi tlf9999,
long way to go down this path before it fits the title I'm afraid.
Let's see.
I like that R1 very practical. The OP amp gain is 10 in a local loop as long as a low Z source is connected. Why a local loop here, it wastes so much that could be applied globally and wastes thePSRR improvement of having all that gain before an injection point.
emitter drive is not so good for loading on the chip and current limiting following stages.
how about nesting the discrete part and save the rest for global NFB should give a far better result.
Greg
You could try to eleminate Q3 & Q4 and turn the FET's around where the output is from the drains instead of the source, you can get rail to rail operation then, and eleminate a pole in the process. Place a pot across R4 & R6 to adjust bias? How does it work without R2 and just using global feedback? Any miller compensation needed? I'm sure other manipulations might also work. Shouldn't a ground be between V3 and V4?
Disabled Account
Joined 2005
yeah. so that I don't have to deleted it or add it in case I wanted to change its value. This way, a sufficiently large R1 just means it is not there. So are thos 1ohm resistors. convenience, nothing else.
unless you can get it stable with just global feedback.
that's why there is R5. the chip pushes about 4ma maximum, within its output capability I hope.
only if I could get it stable.
I have never had any luck with cfp type output stages, especially in a mosfet configuration. tough to get it to stablize.
bias is done via R7. R4/R6 in part controls the gain on Q1/Q2.
unstable.
probably.
no. you can, however, put two capaitors on the base of Q1/Q2 to improve the gain of Q1/Q2 and psrr as well. But it is not a have-to-have for this excercise.
Hmmm how about a nested feedback resistor from output to where R4 & R6 are connected and a divider resistor from there to ground? or is this what guru was talking about. Don't know if that will help stability. Generally I haven't had much luck getting a lot of stability from an AB biased feedback pair drivers...Q2,Q3 : Q1,Q4 although it can be done, not my personal favorite. Lots o' gain though.
Hi tlf9999,
"that's why there is R5. the chip pushes about 4ma maximum, within its output capability I hope."
Howsat? Looks more like 12mA to me given 15V supplies for the chip - a lot for the following stages to deal with and also your chip supplies.
Try grounding the junction of R4,R6 and running a feedback loop back to the top of each. Then go in from the chip to the bases for a high Z chip load. Then you need to work up the output nested loop and the global loop (having relieved the chip of it's local loop).
Your baby
greg
Disabled Account
Joined 2005
Because the opamp isn't swinging 10v in either direction. its actual gain is much lower than that.
the supplies are 12v actually.
here is the current through R15.
Disabled Account
Joined 2005
Re: Re: Ultra-High performance OpAmp-based MOSFET Power Amp
Mr Evil said:
Try an OPA445. They will run off up to +/-45V and are surprisingly good quality for a specialized op-amp. I've use them to make hybrid amps similar to yours before with good success.
thanks. you can also use 541/549 or those lm chips.
The purpose of this exercise is to find out how to expand an opamp's voltage and current output capability.
Re: Re: Re: Ultra-High performance OpAmp-based MOSFET Power Amp
How about bipolars and CFP output stage with some gain like 4x?
might call this one with CFP as a "ultra-stable", if yours is "ultra-high performance" :D
