The -dev packages required for compilation are not installed by default.
Thank you!
Still learning 🙂
Hello from Germany,
i have a error:
src/mixer/plugins/AlsaMixerPlugin.cxx:290:40: error: ‘log’ was not declared in this scope
const float scale = 100.0/log(100/a);
src/mixer/plugins/AlsaMixerPlugin.cxx: In function ‘float {anonymous}::toLogVol(float)’:
src/mixer/plugins/AlsaMixerPlugin.cxx:294:36: error: ‘log’ was not declared in this scope
return x == 0 ? 0 : log(x/a) * scale;
src/mixer/plugins/AlsaMixerPlugin.cxx: In function ‘int {anonymous}::fromLogVol(float)’:
src/mixer/plugins/AlsaMixerPlugin.cxx:300:31: error: ‘exp’ was not declared in this scope
return a * exp(v/scale);
Makefile:10238: die Regel für Ziel „src/mixer/plugins/libmixer_plugins_a-AlsaMixerPlugin.o“ scheiterte
make[1]: *** [src/mixer/plugins/libmixer_plugins_a-AlsaMixerPlugin.o] Fehler 1
make[1]: Verzeichnis „/home/tom/share/MPD“ wird verlassen
Makefile:15628: die Regel für Ziel „install“ scheiterte
make: *** [install] Fehler 2
debian jessie sid on a pc
thanks for help.
a great job
Cliff
i have a error:
thanks for help.
a great job
Cliff
Hello again,
I can now successfully run make install, but still have 2 problems: 1. mpd only runs locally with mpd /etc/mpd.conf 2. No system service My system debian jessie on a pc. Is there something I overlook? Many thanks in advance
You need to change systemd default directory path, this is not unique to this fork, google mpd systemd you should be able to figure it out
I really want to give this a try as I can't seem to get proper hiss-free dsd streaming to work.
But, I get an error when I make:
I noticed the poster above had the same error and resolved it. Just wondering how to get around that?
Thanks!
Code:
Makefile:10238: recipe for target 'src/mixer/plugins/libmixer_plugins_a-AlsaMixerPlugin.o' failed
Thanks!
I was able to resolve the above error by adding
#include "math.h"
to the beginning of src/mixer/plugins/AlsaMixerPlugin.cxx
But, now I have a new series of errors when I run:
make install CPPFLAGS="$(pkg-config --cflags glib-2.0)"
Some Google searching suggests is the order of specifying the library, but I have no idea how to correct it.
Any suggestions would be greatly appreciated!
#include "math.h"
Code:
/src/lib/sacdiso/sacd_disc.cpp:89: undefined reference to `g_free'
libdecoder.a(libdecoder_a-sacd_disc.o): In function `charset_convert':
/src/lib/sacdiso/sacd_disc.cpp:86: undefined reference to `g_convert'
#include "math.h"
Code:/src/lib/sacdiso/sacd_disc.cpp:89: undefined reference to `g_free' libdecoder.a(libdecoder_a-sacd_disc.o): In function `charset_convert': /src/lib/sacdiso/sacd_disc.cpp:86: undefined reference to `g_convert' /src/lib/sacdiso/sacd_disc.cpp:89: undefined reference to `g_free' /src/lib/sacdiso/sacd_disc.cpp:86: undefined reference to `g_convert' /src/lib/sacdiso/sacd_disc.cpp:89: undefined reference to `g_free' /src/lib/sacdiso/sacd_disc.cpp:86: undefined reference to `g_convert' /src/lib/sacdiso/sacd_disc.cpp:89: undefined reference to `g_free' /src/lib/sacdiso/sacd_disc.cpp:86: undefined reference to `g_convert'
I was able to resolve this issue with some help from xxxbugxxx:
make CPPFLAGS="$(pkg-config --cflags glib-2.0)" LIBS="$(pkg-config --libs glib-2.0)"
make install
make install
Actually the instruction on GitHub is already updated.
Also the instruction is updated for diyaudio.
BTW, just updated the fork to based on mpD 0.20.4
Thanks to Maxim V.Anisiutkin
Thanks!
I sync'd, recompiled and it's working great 😀
Hi there, great job!
I'm compiling it for Armbian Xenial on an Orange Pi Zero Plus but am getting this warning:
Other than that, it compiles just fine but (of course) it doesn't end up supporting SACD ISO files.
Any idea what I'm missing?
Code:
configure: WARNING: unrecognized options: --enable-sacdiso
- PC Based
- Ultimate MPD (SACD ISO, Native DSD, and more)
