For Sale UK - Neurochrome 686 - all boards - fully assembled and working
Things you have for sale.
Neurochrome 686 fully assembled
All working as it should, no power on/off thumps just the quiet clicks from the relays
Case Dimensions in mm (approx)
450 wide v 410 deep x 190 high
Note: the sockets and switch add depth so allowing for cables etc front to rear depth in use is about 490mm
The Amplifier Includes:
2 x Neurochrome Modulus 686 boards
2 x Neurochrome Power supply boards – one for each channel, 88000uf per channel
1 x Neurochrome Intelligent Soft Start
2 x Neurochrome Guardian speaker protection – one for each channel
Green Ground/Earth Socket on rear
XLR inputs
4mm Speaker terminals
1 x Mains Transformer 800 watt with separate windings for each channel.
  • 2 x 400 watts windings @ 25vac
  • One winding for each channel
IMG_20240718_120756.jpgPXL_20240718_110644971.jpgIMG_20240718_120717.jpgIMG_20240718_122422.jpgIMG_20240718_122417.jpgIMG_20240718_122436.jpgIMG_20240718_122432.jpg
£2000 firm
