deandob said:Thanks Steve.
Jan-Peter did specifically say the 470uF caps should not be replaced with low-z caps.
See http://www.diyaudio.com/forums/showthread.php?postid=610784#post610784
Have people been replacing these caps and making their UCD400's worse?
Confused.
Dean
I've noticed that as well. I think if you look you'll notice a much smaller set of electrolytics, on my board they're a blue/metallic and from BC (Vishay). These are in fact the high ESR "damping caps" that should remain. I think they're valued at 22uF as well.
Chris
It would be good to hear from Jan-Peters directly on this.
I do see the smaller blue caps and checking the connections they are indeed in parallel to the larger supply caps. As this is the case, these caps are probably specifically selected as matched for this circuit to reduce resonances, so should not be touched without mucking up the intended design or unless you have a scope to detect and tune ringing with new caps.
Can anyone report any changes heard when replacing these caps?
Regards,
Dean
Regards,
Dean
Dean,
Try it!
The smaller 10uF caps are in parallel with the 470uF and will damp the most ringing.
We have good sonic experience with the BCC 135/136 (low ESR) in the UcD700, however the 470uF size will not fit in the PCB.
Jan-Peter
Try it!
Jan-Peter
Thanks Jan-Peter,
I'll try a pair of Panasonic FC caps I have on hand. Easy to swap back if needed.
Regards,
Dean
Regards,
Dean
Is it possible to place digital circuits close to the UCD module? I was specifically thinking about using a CD4013 D Flip-Flop to toggle an on off push button and a 555 timer for a time delay plus some mosfets to handle the current. My fear is that the UCD will blast the CD4013 with EMI\RFI causing it to change state.
If this is not possible I can revise my whole circuit to work with 6 relays, at a higher cost. I don’t know what happens to reliability.
Leve
Leve
Hypex softstart backwards?
I finally got my new bigger transformer so I needed to use a softstart. Since I'd liked the other Hypex stuff so much I went ahead and used their softstart.
However it seems to be wired backwards with respect to the switching feature.
I've already got a main switch, but I bought a pushbutton for the front panel. Unfortuantely I didn't have a big enough metal bit to put another hole on the front panel and it wasn't worth a special trip out for a new bit. So since I didn't have a switch I could use I put the jumper for switch and just ran a wire between the two switch contacts (as if the switch was always on). Of course it didn't come on. I kept measuring different points trying to figure it out. Finally on a lark I hooked up a couple of spare LEDs to see what was going on. With that I noticed that it never came out of standby. After I removed the wire between the switch I finally started hearing the relay switch over.
So my question is this, Is this backward style switching common to softstarts or is there some reason Hypex picked it?
Yeah I noticed this as well.
Maybe the idea is not to run any unneeded currents as long as the machine is on? That's what good design is all about I suppose? Avoid as much potential sources of distortion as possible?
Softstart 'switch' feature
When jumpered in 'switch' feature, the softstart module switches 'off' when the contacts are closed and 'on' when the contacts are open.
It might be the opposite of what you expected. I will have it clarified in the manual.
Jorrit
Jorrit
Maybe this was asked later but will it be absolutely safe to use 63V filter caps with Hypex 2x42VAC transformer. This will give about 59VDC and will not quite offer 10% "safe margin".
I do not know if Hypex supplies use 63V caps?
I will kick off Rotel RB1070 from my Orion woofers and make UCD400.
M&T are amplified by UCD180.
I wonder if you could rig the soft start to use both a button and a remote on feature (using a low voltage connection, like found on many amps and preamps). I'd like to be able to control on/off with a remote. Currently, my amps turn on when I turn on my preamp, and my preamp has many different controls for turning on and off the low voltage connection.
Pasi P said:Maybe this was asked later but will it be absolutely safe to use 63V filter caps with Hypex 2x42VAC transformer. This will give about 59VDC and will not quite offer 10% "safe margin".
I wouldn't. You neglected to subtract the voltage drop of the rectifiers, but then you really have to account for a 10% mains variation, while unloaded (another 5% at least).
You should really be aiming for a safety margin of 20% on your caps, maybe push it to ten, but only after your worst case scenario of 15% overvoltage. Exceeding their limit just once is enough to ruin the sound of your caps, which are usually expensive, and if you're really unlucky they can fail outright.
Thank you Chris. It start to seem that maybe better solution for me is to make another 4-ch UCD180 to drive 4xOrion woofers separate. Not only because i have many 63V caps in shelf but that is also what SL recommended.
To use 63V caps on a 57-59VDC voltage is NO problem. Don't forget the BCC caps do also has a surge voltage what is 10-15% higher as the rated voltage. We use the BCC caps already for many, many years, and NEVER had one failure.
Caps with failure because of rail voltage what is at the rated voltage will only happen with cheap Chinese manufactured caps. There are a lot of stories known about this.....
Jan-Peter
That is why Hypex uses 63V caps in their power-supply's.
(I've been searching for 80V caps all over the world
(Leuke vakantie gehad Jan Peter? Niets gebroken? 😀 )
Indeed! When you have some cheap caps, I would have a voltage difference of at least 20-25%. But with manufacturs like BCC/BHC, you could have a difference of 5-10%.
This counts only for those big snap in capacitors. The smaller caps like 22uF-470uF we use a bigger margin. With a voltage of 65V we use 100V rated capacitors.
Jan-Peter
(inderdaad goede vakantie, en niks gebroken..... 😉)
Jan-Peter
Jan-Peter said:To use 63V caps on a 57-59VDC voltage is NO problem.
Jan-Peter
Absolutely true. Have used Philips 154 caps rated 63 V for over 15 years without a problem on 60V DC supplies for the Crescendo. Not ever did 1 fail.
I still use 63V caps. for 2x 40-42C AC toroids.
Adding zener diodes
Wouldn't simply adding zener diodes either after the diode bridge or after the power supply resolve all the potential issues with over-voltages? My understanding of electronics is feeble at best, but I thought that was the purpose of such beasts, to shunt excess voltage to ground.
Re: Adding zener diodes
Just simple zener diodes won't do the trick. They would just burn-out in no time. Zener diodes can not handle those large currents, and even if they could, you would be waisting lots of power.
Gertjan
markgwoodruff said:Wouldn't simply adding zener diodes either after the diode bridge or after the power supply resolve all the potential issues with over-voltages? My understanding of electronics is feeble at best, but I thought that was the purpose of such beasts, to shunt excess voltage to ground.
Gertjan
Re: Re: Adding zener diodes
A zener plus a resistor at, say, 64V, so that it would only go into reverse bias when the mains drifted over 10%?
Gertjan
- Class D
- UcD400 Q & A
