UcD400 Problem
classd4sure said:
At moderate levels pumping is highest,
Either 25 or 75% amplitude it pumps the most. According to Roger that can affect your pre amp, I guess a simple test would be swap channels and see what happens.
output impedance is really high on the defective unit (megaohms). The other one measures around 10kohms.
It's probably disabled then. If you seperate the enable wires for both modules and just test the defective one (I'm thinking you're running both off one remote LED ??) you may see it blink as I think the protection they use cycles every 1 or 30 seconds.. no idea, can't remember how long.
You're measuring from the rails to the speaker output right so if the outputs were blown you'd see mostly the DC resistance of the filter coil and hear a 60hz hum.
If you're reading Mega ohms you're looking at a mosfet that's being held off. Maybe you could try it with a different pre amp or swap modules channels (try the bad one on the good channel dont' try the good one on the bad channel) maybe you can rule something out that way.
I swapped the modules on the monoblocks. The problem follows the defective module. No hum, no DC at the speaker output. No blinking on the LED.
Hope this help. I REALLY appreciate your assistance....really,
I think I found something. Speaker ground is the the same as chassis grounded on the defective unit.
......but that was caused by an XLR to RCA adaptor in the input. When I remove the adaptor, speaker ground is isolated from chassis ground.
There is 0,71 volt DC at speaker output.
It looks a little high to my unexperienced eyes. I read a few mV in mine. I hope you do your tests with a cheap pair of speakers. Do you have music now?
Be careful with your PS caps while swapping. They may be charged 😱
Avoid further damage to yourself or your module. Wait for the cavalry 🙂
Normally speaker ground must be "floating".
Sorry not to be of any help. I am sending you good vibrations, though 🙂
Good luck.
