I have a pair of the UCD 400 modules on their way to me, now I need to know about power supplies etc..
1. Is a 500va 40volt toroid per channel OK? From what I can gather of the spec sheet it says up to 42Volts.
2. Can I go to a smaller VA rating, eg 300va per channel, or will this limit my output?
3. What is the minmum capacitance allowable for eack side? 20 000 enough?
4. Is a 10 amp Bridge rectifier per channel sufficient?
5. Finally, do the modules come with a basic diagram showing how to wire the transformer/rectifier/caps? If not can anyone direct me to one.
Thanks for any advice, Beau.
