Increase R36! (And decrease C18!)
Please, do not forget to do the same with R35 and C17...
Also, I would like simply use the additional opamp at the input with required gain. Hypex does the same, by the way...
With this formular, I have increased R36 to 22K and reduce R101 to 470 ohm.Also reduce C18 to 220pF .So gain is 39.196 .
How does it effect to the performance of the amp? Is it the noise ? Or any others? What is the good solution between increasing the gain of the amp and increasing the gain of balance receiver?
- Class D
- UcD need help for more gain
