I need a crossover for a a 160watt sub with a crossover frequency of 80Hz to 100Hz but i can't seem to be able to get one anywhere within the UK. I have found crossovers but they have all had the wrong frequencys etc.
Does anyone know where i could get the one i need?
Hi there.............a car accessory shop for boomers might provide an instant solution. OR .... nudge--nudge ...How about knocking-it up with an op amp or two..... ?? the math isn't that shocking........
rich
rich
This will give you an instant solution.......however, at this low freq THD isn't an issue until you hit the lower vocal 250hz+. Generally they come with in/out level adjustments.... they might be some tinkering to adjust to system. The phasing is something you might have to experiment with.
rich
rich
Thanks for your help. I ordered the crossover so hopefully it will be here soon and i can get my sub into action.
