Hi im new around here !!
Have this Amp , came in protection !!
NOne mosfet burn or Bad .
Following Mute from Output drive card ,
Find a M6 transistor bad , replace it and the amp turn on !!
Testing the amp find out that output lowside mosfets are a little bit warm , putting signal in and speaker they gone more warm than usual , HIGHSIDE not they have normal temp.
Pullout output mosfets and test all drivers , follow waveform from drivecard to mosfets pads , its fine square.
When I load the output fets the waveform on gates of low side get distorted .
The Highside are ok completely square .
Any idea whats going wrong on it
Low Side Gates loaded!.
Hi thanks for respondig .
It use a 2X smd and D667 & B647
The Base of the 2x also distort de waveform , the collector waveform much better .
I can't tell what is happening exactly because I don't have a schematic. However, I think that there is a problem with the npn D667. I see some solder cracks so I would reflow the solder connections of D667 and B647 first. If resoldering doesn't help then you should check those 2 transistors for opens or shorts. It does seem like there is an open transistor and it might be D667. Make sure that the collector voltage is correct on those 2 transistors.
Thanks !!
I reflow them , still the same .
Changed them with C2073 / A940 nothing change .
Replace the 2X , nothing.
Got 2 mosfets on each side , right now they are cold with that lowside drive deform .
The collectors have 12V from input of the 5v regulator and the other one -B .
I noticed theres +5V on speaker terminal .
Also Change this two Resistors , from rails to GND .suposed to be 100K and only measure 10K .
Hii
Okk i try to make a schematic but i noticed that the SLA1500 Schematic is almost almost identical the only thing that changes its the driver output.
It use a 2X smd transistor after opto 6n137 .
After that change from sla1500 instead of the 2X and 2T it use the D667 and B647.
Trying resolder lowside smd's components . Nothing happen.
Use the C1023 and A940 same thing .
Use the D718 and B668 worst .
Resolder feedBack circuit , samething
Right now at idle have loaded with 2 mosfet on each side , now at idle are cold , load input signal and a speaker and they getting warm , but the waveform like a shar fin
I Also thinking about that , if the problem is in the driverboard , the LM319 is getting signal , i saw the triangle wave in the 4560 opamp.
Pin 9 of the lm319 show this , is that normal ?.
I think that pin 9 of the LM319 looks normal. The drive out of the opto-coupler or into the opto-coupler is insufficient. This can happen with cold solder joints or a component that has changed value. I still suspect a cold solder joint because some solder connections look suspicious. Years of thermal cycling can make a cold solder joint reveal itself. Put some pressure with a pencil eraser or your finger on the components in the bad area to see if there is a pressure sensivitity.
Thanks , just did it , no changes on the bad area .
Recently tried with another output driveboard , still the same .
- Class D
- Type 4 Class D GMAudio 3K lowside issue
