Hi guys,
I wonder if it has been done, and what would happen if for a 2 way, the midbass driver is placed into a sphere of known volume and then two PVC pipes are supposedly interconnected into the sphere. One PVC pipe will be closed, the other will have a port to mass load the TL. The main ideas are:
-simple materials to experiment with.
-two pipes, one will serve as the speaker offset to kill the closest harmonic
-street lamp plastic sphere as the primary driver enclosure to reduce back radiation of waves towards the cone. P.S I need to check the BSC frequency with spherical enclosures.
The fullrange speaker can then be mounted inside a second sphere, where a "pseudo Nautulus" can be built, a sphere with a pipe opening and aperiodical stuffing.
What do you think of this idea?
Sounds quite promising. Are you planning to try it out?
Why would you need the second sphere though?
