Two Way bookshelf speakers advice - crossovers
I'm looking to build a pair or low-ish profile two way bookshelf speakers. I possibly intend to wall mount them.
I've built up the crossovers on VituixCAD and I've noticed that the impedance is hitting a low 2ohms at about 4khz. Is this going to be a problem for driving them?
I'm currently using an old Onkyo TX-SR705 amp with certainly is fine with 6 ohm speakers but maybe wouldn't do so well with 4 ohm?
My drivers are:
Tweeter - Dayton Audio RST28A-4
Mid/Bass - Dayton ND105-4
Please see the crossover image.
Crossover Only: dayton-pc-speaker-crossover-diagram — ImgBB
Crossover + Graphs: dayton-pc-speaker-crossover — ImgBB
*EDIT for different picture link*
I am struggling to read that crossover, my friend.
You'd do better to upload the circuit to the forum with the paperclip tool in the reply box.
Keep it reasonable size, around 640x480 jpeg. Forget the graphs for now.
Looks to me like you need a bigger bass coil as a start. Should sort out the impedance.
I wonder if that LCR notch on the midbass is causing problems?
Eekels' Mini
This is an 8 ohm circuit, but it drops impedance a lot.
With 4 ohms, I think you can't use an LCR notch:
Vifa PL14WJ-
Troels keeps it simple LC filter with the 4 ohm D'Appolito circuit. Hard to say if you can apply a notch to the metal driver. Converting an 8 ohm circuit to 4 ohms usually involves halving coils and resistors and doubling capacitors. The R2604 here is a 4 ohm tweeter, so that might work with some level adjustment.
You seem to be struggling to bring that treble down, but you're doing the right thing. Find a useful tweeter filter damping level by varying the components and resistor as they sometimes oppose each other. Or, add a parallel resistor with the tweeter.
