Two premium Whammy Kits
Two part built boards plus transformers and op-amps and one bare PCB available.
Two whammy PCB's part built very carefully with premium components. All components are fresh and brand new, the main DC filter caps on both boards have been used from my stash and are slightly mixed but high quality.
Both boards have been built to the standard configuration with 60mA bias (10 Ohm resistors), LED reference for regs, 4.75K for gain.
Included with both kits are 2 x 6.8K resistors to give extra gain, 2 x 3K resistors for input , 4 x Fairchild Mosfet transistors, 2 x On semi 15V regulators.
Also a choice of op-amps all mounted, first come gets first choice - OPA1622, LME49710HA x 2, LT1128 x 2, LT1115 x 2, OPA604 x 2
ONE KIT LEFT
Premium kit - Hammond case with Powercon connectors and cable, PCB is brand new never used, built using premium parts. PIC IN POST 6
4 x 4700uF UKW & 2 x 1000uF ukW filter caps
Bunch of good op-amps.
£50
Optional (240V) Custom Toroidy transformer - £20
Optional Sonic Labs Ticha 994Enh discrete dual op-amp - £40
