Two 15amp switches in parallel ok for 30amp load?
Hi all,
Simple question here. Would two 15amp SPDT side by side SPST switches wired in parallel with their toggles taped together be safe/acceptable for a 30amp load? I have 30amp and 20 amp AC shore power options on my RV and I want to institute some kind of solution that will not allow power to be fed by both lines at once. A SPDT switch in the hot line seemed like the easiest solution, but finding a 30amp 120v single SPDT switch is proving to be difficult and costly. 15amp switches can be had for less than $10. Am I completely off base in my thinking here?
Thanks for any help!
Gotcha. What if there was no load on the switches when the switch was made. In other words, could the contacts themselves handle the current once the switch was already flipped?
Thanks for the lead! I've never heard of a shower switch. Is there a SPDT shower switch? Any other suggestions would definitely be appreciated!
