For Brian and Russ
Gentleman,
Yesterday I had the time just before leaving on holliday to change my Buffalo for the Buffalo 32s in my cd-player, also a extra LCBPS for the analog supply went in with his own torroid.
After the first cd went in I couldn't stop listening hours went by and I forgot everything, only music music music as it should be.
For the first time everything, detail,depht, 3D it all was just right, also the emotions (with some special tracks from my late father) that came over me,shivers and tears in my eyes, never ever I could feel so much emotion and feeling in music.
I guess this story speaks for itself, thank you guy's, you are truly a gifted pair.
René. 😀
Gentleman,
René. 😀
Thanks Ren,
That's the kind of encouragement that helps keep me going! 🙂
I am very glad you are enjoying the DAC. Brian does a truly amazing job pulling all of the logistics together. I could not do what he does. We are a good team.
Cheers!
Russ
Cheers!
Russ
I am pre-ordering the kits, but will the dual mono supply option be the best bang for the buck?
-joe
-joe
BrianDonegan said:No. Dual-mono is more for "every last drop."
thanks!
i guess i was thinking if i am going to do it once and do it right, might as well go all the way since the price differenence isn't that great
-joe
Question about I2S and SPDIF
Hi guys:
I have both I2S and SPDIF sources and want to design the cleanest input switching scheme. I think I can make use of the onboard comparator with some switching. I will use the cute little Thumpbuster relays, or may purchase an Otto.
If I understand correctly, the SPDIF input header is connected to a comparator and the little SPST switch connects the output of the comparator to the D1 input.
Is that correct?
In my idea, one switch will select the SPDIF input and connect it to the SPDIF header input.
Another switch will connect to the D1 header input and select either the I2S source or the output of the SPDIF comparator.
Other switches will disconnect the remaining I2S inputs when SPDIF is selected. I assume this is necessary.
Should I2S inputs be grounded if not used?
If this will work, which end of the SPST switch do I want?
The end closest to the input header?
Is there an easier spot to pickup the output of the comparator? I am concerned about tacking a wire onto the solder pads of that SPST.
I think the attached schematic will work. With both relays OFF, I2S is selected. Both relays ON, the SPDIF input is selected and the I2S inputs are open.
Hi guys:
Is that correct?
Hey TP guys,
I know you are busy... I was looking at the "tweaker's layout" and think it is great if you make holes where the caps are(caps can stay) for through hole mounting. Also, would it be possible to have a jumper system put on the board so that the outputs can be summed closer to the DAC? Other than that, Could you hurry. LOL. Seriously though... I am heading back to the jungle in a month and need all of the parts before I go. Just pull the trigger and get a couple boards made and I will be a BETA or whatever the other guys gets all excited about! The fact is that I need a chip mounted on a board soon and the Jkeny way might be my only option unless you guys can get yours done. I would be very happy with those changes, but I will settle for the current idea. Thanks and I hope it is soon as it is not easy or reliable to get mail where I will be.
And finally, what I hope to be the last set of inane questions I have to ask......
Firstly, open to all comers. Can anybody please tell me what length standoff is included with the TPA kits for stacking the boards? I am guessing between 0.5 and 0.75 inches would be fine, but confirmation would be handy.
Secondly, to Russ and Brian specifically. Has a decision been made regarding the fate of the existing USB receiver module? If you are planning to restock, then I will grab one. This is my preferred option, to be able to stack it with your MUX module. If you are not planning to restock, then I will build myself one of AMB's Gamma1 boards in USB-to-SPDIF form.
Thirdly, and back to all comers. Does anybody have a drawing showing the dimensions of the square cutout and screw hole required for the TPA Toslink module? I have searched fairly extensively and can find plenty of info on electrical characteristics, but can't for the life of me find any physical info.
Thanks everyone! 🙂
Thanks everyone! 🙂
Sorry for the off topic question.
Do you have a link to that USB->S/PDIF board? Does that support 24/96?
Cheers
Thomas
Cheers
Thomas
thomaspf said:Do you have a link to that USB->S/PDIF board?
Yes! http://www.amb.org/audio/gamma1/
No! 😉
Beefy said:And finally, what I hope to be the last set of inane questions I have to ask......
Thanks everyone! 🙂
All base standoffs (F-F) are .5". Stacking (M-F) are .625". Both are .25" diameter and 4-40 threaded (included screws are .25" 4-40).
We are probably going to go with a small panel mount version of the USB module rather than the full size board. It can mount over, under or beside a Toslink or RCA jack with two 4-40 screws. It will output S/PDIF and I2S but not have line outputs and will be USB buss powered. It will be small, but dimensions are not final.
Torx connector: http://media.digikey.com/pdf/Data Sheets/Toshiba PDFs/TORX142L.pdf
BrianDonegan said:......
Thanks, as always 🙂
Pity about the old USB module though. I'll guess I'll just have to wait and see what the format of the new module is before ordering any gear 😱
Recieved and installed my new B32S.
An excellent product, excellent sound (out of the box)!
Thank you.
Thank you.
Ground again
I got my Buffalo32S last week and make it sing couple days ago. Wow, they sound great right out of the box. I have one question about grounding.
Currently, I connect both AGND and GND into one point at my box and then connect to ground at AC line.
I just read the tread and found that the recommended method is to connect ground by shorting L1 and L2. If I do that where should I make connection from the board to the box ground.
Re: Ground again
I usually don't connect the cct GND to mains GND. But if you do so, I would do it at the PSs as close as possible..
WT said:I got my Buffalo32S last week and make it sing couple days ago. Wow, they sound great right out of the box. I have one question about grounding.
khundude said:Hey TP guys,
Should this be posted in another forum to get a response due to the fact it is not exactly "Buffalo 32S?"
The board is much better than what was posted earlier. It will allow for paralleling channels etc.
Career changes force me to not spend as much time as I used to on this stuff. But it is still in the works.
Cheers!
Russ
Up and Running
Hi all:
After many self-created rabbit holes
my Buffalo is up and running and even singing. Very nice.
Thanks for the help Brian and Russ and James.
Larry
Hi all:
Larry
Finished assembling the B32S dac.
Great sounding, and perfect functionality.
The thump buster is neat and works nicely.
Hate I had to cut the traces to enable the output R on this beautifully made board. It should be implemented the otherway around, adding jumpers for headphone use. But R at output does make audible improvement when using the dac with preamp.
Kudos to the TP duo!
Prakit
Prakit
- More Vendors...
- Twisted Pear
- Twisted Pear Audio - Buffalo32S (ES9018 DAC)
