Working on a two way project with a Scan Speak R3004 and have a basic mounting question.
The front baffle of my speaker is almost 2.25" thick. After routing the recess for flush mounting, can I simply route out the center to to say a depth of 2" (total mounting depth of the tweeter is ~1.25")?
Does such a small volume present thermal issues for the tweeter?
Or should I simply cut through the baffle and allow the tweeter and mid to share the compartment?
Appreciate your input
Ryan
Ryan
Unless the tweeter has a vented pole piece I can't imagine that small cavity would cause a thermal problem for the tweeter.
If you have doubts - simply drill through (a single hole) instead of routing the entire thickness.
