Hi!
I have a tweeter and I don't know what is it's sensitivity. There isn't any info about it only some driver parameters:
-Z (Ohms)= 8
-Mmd (g)= 0,27
-D (cm) Diamètre émissif de la membrane = 2,95
-Sd (m2) = 0,00068
-Rcc (Ohms) = 5,25
-Bl (T.m) = 3,406
-L1 (mH) Inductance de la bobine à 1 kHz = 0,315
-Res (Ohms) = 40,9
-Fi (Hz) = Fréquence de résonance sur baffle infini 1250
-Pmax (W) = 30
Could somebody help me?
Greets:
Tyimo
-Z (Ohms)= 8
-Mmd (g)= 0,27
-Sd (m2) = 0,00068
-Rcc (Ohms) = 5,25
-Bl (T.m) = 3,406
-Res (Ohms) = 40,9
-Pmax (W) = 30
Greets:
Tyimo
Well, the sensitivity rating on a speaker is with the speaker driven by 1 watt of power, and measure with a reference microphone at a distance of 1 meter.
Although, that only works for 8 ohm speakers. The applied signal to 8 ohms to achieve 1 watt is 2.83v. So, most speaker manufacturers test SPL at 2.83 volts regardless of actual impedance.
Most hobby users are using a cheap condenser Microphone (Panasonic?) that they have built into their own slim mic holder. This can be done for about $25. To buy a reference mic for speaker testing would usually cost you closer to $100.
So, apply 2.93 volts to the speaker within it's working frequency range, and measure the sound pressure level in DB at 1 meter, and you will have the rated sensitivity.
Steve/bluewizard
Steve/bluewizard
Thanks Steve, but I don't want measure with mic.
I would like to know how the WinISD and other program calculate it from some TS parameter data.
Tyimo
