Hi. Jst wondering if anybody has had any expirience with these tweeters.
Seas 27TDFC
Peerless 810921
Scanspeak D2905/9500
They are going in a MTM 2.5. The mid woofers are VIFA PL18WO09-08. I heard alot of good things about these tweeters but don't know whichn to choose, also the Scanspeak is pretty expensive.
Seas 27TDFC
Peerless 810921
Not to discourage you, but the 27TDFC is a fine tweeter, less expensive, and easier to implement - Peerless needs more crossover components to really get it right due to rising response.
Thanks sdclc126, I will be using an acitve crossover 12dB LR in a biamped setup. Which would you choose? What is a good crossover frequency fo the 27TDFC or 810921
You really need to model the crossover with software - there are several free resources out there, such as:
http://www.pvconsultants.com/audio/frdgroup.htm,
and a good guide to the above here:
http://www.rjbaudio.com/Audiofiles/FRDtools.html
I wouldn't be able to suggest a crossover frequency offhand, perhaps someone else could - but you need to use the T/S parameters of the woofers and tweeter to design a proper crossover.
maidenfan said:Thanks sdclc126, I will be using an acitve crossover 12dB LR in a biamped setup. Which would you choose? What is a good crossover frequency fo the 27TDFC or 810921
Look at the not less impressive MDT-30S - Morel high power handling tweeter:
http://www.eltim.eu/E_frame.html?http://www.eltim.eu/
http://www.google.com/search?hl=en&...andling+tweeter+&btnG=Google+Search&aq=-1&oq=
- Tweeter selection
