Tweeter for 98db speaker 4.5k and up, help!
Hi, I'm looking to recreate some JBL CF-150's and have sourced the woofers and midranges from "that auction website".
However the tweeters N/A, so I assume that's why the guy parted them out.
The speakers are 98db sensitivity and sound great on 4 watt triodes (I Have another pair), so that's why I want to build another set.. however I need a tweeter that will work with this.
So does anyone have any suggestions for a tweeter that'll go nicely with this, from 4500hz and up? I see there are some ribbon tweeters that are high sensitivity, what's the verdict on that?
Also, I'm one of those guys who like the Le25 tweeter better than the newer 035ti titanium dome, it just sounds better..
Any help appreciated.
I just looked into the JBL CF-150 details and conclude that they are more likely to be a 95 dB speaker rather than 98. They use a dome tweeter. (some specs. exaggerate)
As you mentioned, some ribbon & planner tweeters could do the job due to their high
sensitivity, however, you have to live with their dispersion characteristics.
(vertical & horizontal dispersion is not equal with ribbon & planner tweeters)
A perfect HF driver/tweeter selection for your project is the Beyma T2030.
The Beyma T2030 drivers cost about US$80 each.
If you decide to go with a high SPL horn tweeter, connect it via an L-pad to 'tune'
the output level. (I am running my tweeters via 50 watt L-pads)
Good luck with your project,
Mark
