I got 15 of those
there is a plan to use them in a 2 way design
Woofer i will use does very well in the midle area and its a real 100W woofer
can anybody share his expirience with these tweeters ?
https://www.audiophonics.fr/en/twee...bSB_7gQ--mzGVRJWeh2wjmVjdBW6UbeUG1pEjyye0NE0I
Need to know one more thing
does this tweeter require some enclosure from behind ?
The data sheet doesn't seem to provide useful information about mounting. It does mention a bracket. Does it come with a bracket to mount it on?
Not knowing about the design of the bracket it may be sensible to play safe and give it a protective, minimum sized protective chamber of its own to limit any affects from large bass signals.
Maybe give it its own little separate enclosure / pod to live in, then you can play with position in terms of its directivity and time alignment with the other drivers.
