My car just blew the right front tire.
Which tire should I buy instead?? Get it??
Welcome to DIYA btw.
Unless you don´t supply the info of at least brand and model number of the TV........ I doubt, you will
get any answer at all. I could give you the value of R461 in my monoblocks, but that probably wouldn´t help either
If you have read R461 off the circuit board it is likely to be a sequential component number to correspond with the schematic.
It is unlikely to be a component value.
Unless you have a schematic or the component has readable printing or colour bands then you are unlikely to find an answer.
Also, be aware the component may have burned due to another failure.
Post a picture of the failed board and brand and model number of the TV. You may get lucky and someone may be able to help.
