turn your audio amplifier into power generator (manual)
This is nothing more than a very rudimentary power inverter which usually do not use amplifiers built for audio. A better design would have been to synthesise the AC output using pulse width modulation much similar to the way class D amplifiers synthesise their output. In that case you need a sine oscillator working at 50/60Hz.
If you need money to complete your studies, my advice is to raise a charity campaign. Get your ideas from charity organisers. There are many around.
From here, what you will most probably get, is contempt and ridicule, as this place is not intended for this kind of activity. Yes, there are people who do business here, but let us be sincere, their products are often excellent and their builders are highly knowledgeable and experienced.
Reactions: MrKlinky
This post belongs to the Longue section where other snake oil entertainment is.
I did not read the entire pdf but only looked at the circuit diagrams and some text. If this is the case, and this is a joke, let it be.
Actually, energy can be unlimited, but one has to find a way of converting mass directly into energy. Fusion and fission do it, but those are extremely expensive to achieve.
If my memory serves me right, there is a hypothesis which states that empty space has an energy density in the order of 10^120J/cm^3. This is more than the energy contained in the entire Milky Way mass!
Reactions: MrKlinky
I was building this and it worked. I turned many amplifiers or amplituners into power gens, even made 3 phase version. Don't blame for a start. Give it a try 🙂. Audio stuff is very good to such purposes. It only requires grounding. I tried to be very obvious in my manual. And no, this is not a joke 😛. Greetings!
Dxer
Dxer
Then, it is strange that you ask for donations. Considering current energy prices, your free energy source should provide a lot of money. Let me propose several steps.
  1. Power your house with free energy that you, as you claim, have.
  2. With spared money, build big generator and sell energy to the power distributor. Solar panels will be made obsolete.
  3. Provide theoretical explanation for this free energy and win a Nobel prize.
Simple as that. 😉
Noplis, truly was an old Polish joke. Men were hunting on safari, and after all, a colleague ask: what have you managed to hunt? - A giraffe, hippo and also one 'noplis' was there. A noplis? - Yes, he was roaring in the bushes: No, please!, No, please!
Many years ago I used to power home with paulos, but the ability of power is limited only up to say 3kW. Now I am using standard solar power and grid...
Yes, if you managed to build, you can find an amateur to sell it 😉 I know there are many hobbyist here with good skill of electronics. People in my village still use my inventions... But now I am getting old, so I thought: I will spread it to people.
I don't like secrets you know... It's time to open source this. And honestly I like to share with infos. I am ill on severe disease, that's why I don't care now. I have more on the topic. Write me a PM and I will send you info for free.
Dxer.
Ps. For some guys it's known, for some it's simple but unknown, for some this cannot work, though they never solder...
There is a source of free energy out there, it is called the Sun. It is a naturally occurring fusion reactor converting about 4000 million kilograms of matter into energy every second!
Using this information, the power in watts of the sun, is:
Code:
P = c^2.[dm/dt]
P = (3e8)^2*4000e6
P = 3.6x10^26 Watts
If this power is evenly distributed, this would be equal to a power density (power per square metre/intensity) of:
Distance between the sun and Earth is 1.5x10^11m.
Since all photons from the sun travel at the same speed, this power is distributed over the surface of a sphere of 1.5x10^11m.
Therefore, the solar intensity before photons enter into the atmosphere is:
Code:
Intensity, I = Power/(area of sphere of radius 1.5x10^11)
I = 3.6x10^26/(4*3.142*(1.5x10^11)^2)
I = 1.273kW/m^2
Yes, but energy is also in the grounding and in inductors. If inductors are treated with the right signal (mostly sawtooth), they can add current into the circuit. Also capacitors have ability to gather electricity from field (they have aluminium cover, not steel). A normal amplifier is underunity but when you cover the losses that are only few percent, you may achieve a device that gives extra current. I heard even, that some of the amplifiers treated with sunlight or lighbulb had more energy inside. You may observe this in my configuration.
A method which might work to generate some electricity from ambient temperature differences might work using a Sterling Engine (the gamma type). This consists of a large chamber with a very light piston used as an air/gas displacer. The latter, does not fit tightly like an ordinary piston, but is loose to allow air/gas to flow past it. The motion of the air displacer piston is such to displace air from one warm/hot side to the cool/cold side. This way, the air inside the chamber experiences a change in temperature causing its pressure to change as well. A narrow and short pipe connects the chamber to a cylinder in which an air-tight piston is installed. The air-tight piston drives a crank shaft with two cranks at right rangles to each other. The other crank is used by the light piston.
The Gamma Sterling Engine can be installed with the cool end buried in the soil in the ground to take advantage of the cool soil with the warm side exposed to the air and the sun. This creates a temperature difference which can drive the engine and a generator.
The cool end can be installed in air to take advantage of the cooling effect of the evaporation of water which cause the water bulk to cool.
Reactions: MrKlinky
Very interesting. I heard that some of the guys took an old car 4x4, and put ac generators instead of wheels. Though this needs fuel.
Also I've tried connecting an amplifier with tv flyback and kapanadze coil and this worked like in SR193 schematic. The minus was that spark gap had 'living electricity' on it. So high voltage was there. Now I try with amplifier, microwave oven and Dally Kapanadze coil, this version has no spark gap.
I think in ambient there is much energy to gather using for example antennas or big piece of tin. Only it needs the right application to suck this energy and transfer to higher voltages. I've tried those technics in my childhood and this worked, but sadly i cannot remember the application.
The Sterling engine is based on well proven thermodynamic principles, contrarily to overunity and other free energy BS discussed above. Next I am sure we will hear about the magic power of crystals and magnet-powered perpetual motion engines.🤣🤣🤣
I think there are many lies in all physics teaching magnetism and electromagnetism, to hold us under electricity grid lines. Once i put a transformer and little speaker on the phase and i was able to hear my neighbours talking in the speaker... so what was the purpose of energetic lines before internet? to spy? for me it's obvious.
Prior art. Pump and water-wheel. Known since the 1600s.
P. Valentine Stansel's Device. Prior to 1657​
A, B, C is a large cistern of water, above which is another cistern D, E, which is supplied from the lower cistern by the pump X, operated by the water-wheel M, N, the crank L of which is attached by a rod K to the horizontal beam H, I, K, which swings at H, from the side of the upper cistern, as shown at F, G, H. The force-pump X, on the depression of the plunger O, causes the water to rise up the vertical pipe P, Q, R, S, and thence discharge itself into the cistern D, from which a small portion is allowed to escape through the short pipe T, V, whence it falls on the water-wheel, and so on continuously.
