Turn off pop.
I turn my diy amplifier on and off with a 5V relay. The SMPS has power for about a second more after the relay have cut. So I was thinking that I could have another relay mute my 2 boards at the same time it turns off the SMPS. This would make the turn off pop go away.
Can I short the mute from BOTH boards in 1 relay or will I have to use 2. 1 for each board.
Im a bit reluctant from "just trying"
Edit. I have 2 x dual chip TPA3116 boards.
