Tuneful bass at low levels
alspe said:
Hi to all.
With Consonance M12 I meant that large driver has lot of area so it don't have to move lot --> tuneful and quick bass? And wide baffle give more direct upper bass, not just room reflections.
Hence I suggested this 12" GAMMA with very nice pecs... 94db, 25hz, Qts 0.42 ... ideal fore closed box
Ofcourse, if you can afford a Supravox woofer its a different matter...it will be different, though uncertain how much
BTW.. I can tell that the GAMMA woofer has its origin in a very popular 3way "monitor" loudspeaker kit here in Skandinavia from around 1970, maybe a even a bit earlier
Drivers were "cheap" and made in eastern Europe, with ALNICO magnets
Tweeter was a copy of the famous DECCA horn ribbon
They seem to still sell the 5" mid as well
Although this new Gamma woofer looks similar, I expect it to be quite different, specs and all
But admittedly, its a bit hard to choose a driver which no one knows anything about...obtainable around here, the only other big woofer with low Fs I can think of is Supravox and I reckon quality is no issue with that, but cost serious money
Well, there is the SB Acoustic drivers, but quite different beasts
I have a pair of CSS FR125's in BIB enclosures as my bedroom system. Despite having tiny little drivers they wound up sounding rather bass-heavy at higher listening levels. That's never a factor in the bedroom, and the balance works quite nicely at lower volumes. Plus they have a small footprint are happiest tucked away in the corners of the room.
tinitus said:
I dont know, but I suspect that well behaved soft suspended light cones are essential fore dedicated low level listening
Well, as I previously noted, I mostly agree, though a light cone isn't a prerequisite if the motor's strong enough and the XO is appropriate for its pass-band.
GM
This I can believe based on my experience with a pair in some 40-1354 MLTLs, so want to try them in some form of BIB to further extend them.
GM
