Nothing new under the sun....
Because i knew that...i have asked you ???
cheers 😉
fdegrove said:Hi,
Yes, of course...the point was however that you can't just do that with any tube.
cheers 😉
I/V
Just to tease you:
And I can make it work without any gridleak R at all but you'll need to think it through...admittedly it only works with some DACs.
Caio, amigo meu,😉
Just to tease you:
Caio, amigo meu,😉
The comum grid stage...
With a grounded grid stage!!!
salut!😉
fdegrove said:Hi,
Just to tease you:
salut!😉
RE:The comum grid stage...
Nope, same circuit as before bar the gridleak resistor...it's tricky though and it's much easier just to use the resistor for I/V conversion but it can be done.
Don't waste your time looking for a solution, it's only obvious when you're having it right in front of you.
As I said I'm a bit of a tease and you're a bit like me so that's why...
Ciao,😉
Ciao,😉
Something new...under the moon!!!
Can you clarify it...in the name of the "Science"!!!...
Arrivederci 😉
fdegrove said:Hi,
Arrivederci 😉
RE:Something new...under the moon!!!
Ah,ah...gotcha.
There you have your answer...look out through the window, it is full moon isn't it?
No, the trick is to us the output impedance of the DAC as a gridleak for the tube.That only works if that impedance is reasonably linear across the band and very low.
Which is rarely the case, hence my remark that it's easier to use a gridleak of low value to do the I/V conversion.
Cheers Jorge,😉
Ah,ah...gotcha.
Cheers Jorge,😉
The powerfull grid!!!
Oui la Lune est trés belle aujourd'hui !!!
But how can the grid "suplly" the 1 or 2 mA that the DAC need??
A bientôt 😉
fdegrove said:Hi,
A bientôt 😉
LE MONDE A L'ENVERS.
Eh,eh...
The grid doesn't supply anything, the DAC does the work.
I hope you understood it correctly from the start, it's the DAC feeding the tube stage not the other way around.
Cheers et a bientot quand-meme,😉
Eh,eh...
The missing current....
But the DAC for to work need to source or to sink 1 or 2 mA...where in this case they come from??
il ne faut jamais remettre au lendemain ce qu'on pourrait faire aujourd'hui.´😉
fdegrove said:The grid doesn't supply anything, the DAC does the work.
NOTHING'S AMISS...
Last one for tonight...
The DAC sinks the current into the natural impedance that exists when the tube is added, i.e. the resistance between the grid and ground when the cathode of said tube is at ground potential.
As said it seems complicated, it is'nt and it doesn't always work well.
Just don't take it for something you can just do and get away with, I understand you want to get to grips with this but I certainly won't proclaim this as "good practice", I just wanted to get you thinking a little.
More importantly,I'd never put out any product made like this, it can "work", sort of.
From a designer POV see it as an exercise in engineering, not something you want to to market with, the balance is just too delicate.
Absolutamente.😉
Absolutamente.😉
The best option...
Yes...is better to see the full moon!!!
Bonne nuit 😉
Bonne nuit 😉
PALABRAS.
Ola muchachos,
Desde el momento que se comprende el Frances o Espagnol ningun idioma Romano parece difficil a hacer faltas.
Always found linguistic skills to be the key to intercultural communication...😉
Ola muchachos,
Les mots Portugese, je les ai lu tres facilement!
Ola SY...boa noite!!
Its not Portuguese...it's Frenche!!!
But is also a latin language...😉
Regards SY
SY said:Les mots Portugese, je les ai lu tres facilement!
Regards SY
Two thousand times...
Specially in this internet times...as the world is a globall village...
cheers 😉
cheers 😉
Re: Ola SY...boa noite!!
Oh, drat! I thought I had suddenly figured out how to speak Portugese!
Oh,I forgot....
Rectifiers to be avoided:
EZ40,EZ41,EZ80,EZ81 of any brand
6X4 of any brand
Awful!![]()
What's wrong with them?
They continue to hammer out HT for may thousands of hours.
Translation:OK,enough is enough!
(and please spare me on "how bad I made my test rig" stuff...)
"La la la, I can't hear you"
My shop "ears" currently go out to 100 Mhz. But the crappy ones stuck to the sides of my pie-hole seem to be pretty low bandwidth and really are only good to 18KHz or so. I want a refund.
The only real tubes to avoid are chinese power tubes (or they were to be avoided). A friend had fire shoot out of his Citation II because of chinese KT88's.
Sheldon
Me too.. 😱 Other than that can't think of any tube that is not applicable to some application if you want it to be. FWIW, I can get 250kHz out of a 12AX7/ECC83, its only major problem really is the inability to drive a reasonable load directly, (aside from noise performance and miller capacitance) and as SY will explain that is easily fixed - and its quite linear. I've heard much worse, not that it is any sense a favorite of mine either.
Lots of people around here use 866A in big, high voltage DHT amps so a prior comment about its applicability is not true either.
- Tubes / Valves
- Tubes to avoid
