Hey guys,
I have had a good 6-8 months of no issues on this amp, but now another one has cropped up.
it is currently popping the fuse right at start up, with no tubes installed.
any advice to start with, on troubleshooting?
At first, make a current limited power supply, inserting a series lamp (Filamentary, not led nor fluorescent), making an extension cord, or with two crocodiles, and replacing the fuse with the lamp. So you will stop blowing fuses unnecessarily. The lamp must be more or less twice the power expected to consumed by the DUT. Without tubes, it must not light or at most, a brief flash when charging the 'lytics of the rectifier sector, but post this flash, lamp must be almost dark.
Second, measure with a VOM some important points: rectifiers, 'lytic caps, wires, switches, etc.
Third, disconnect (Unsoldering) some points in away to individualize the part of the set that is causing the fault.
Take care with high voltage points in the circuit.
The usual cause of start up fuse shorting is the diode rectifiers, but they do not look to be installed in your amplifier.
The power supply filter capacitors are across B+ to ground. I would check those filter capacitors to make sure one or both have not shorted or become leaky.
As stated, it looks like the solid state rectifiers are not installed, If so remove them and try again.
This happens without the rectifier tube?
If so it has to be in the power transformer or its wiring. We can use the process of elimination to narrow things down.
As mentioned the light bulb tester can make life easier and save a lot of fuses.
Assuming the fuse blows or the bulb glows even without a rectifier tube, disconnect one secondary at a time from the board and test again. If all secondaries have been disconnected from the board and the fuse still pops, the board is not the problem since it is no longer connected to the transformer. There isn't much left except the transformer and its wiring. Look carefully at all the wiring, especially where the wires come out of the transformer and go through the chassis. Any worn spot needs to be fixed.
no rectifier tube.
i finally got a couple tools and pulled all of the all the secondaries and it still popped. i checked the wiring through the chassis and it looks solid as well.
should i get an ohm reading between the 6.3 and ground? i see about 9.25k.
between the 375/375 im getting about 48.8
and the 5 and 6.3 are showing very low resistance
so im assuming at the moment its either a switch problem (tested but i have a second one to verify with)
a wire hitting the chassis somewhere
or a bad power transformer, which is only a couple years old.
does anyone have any ideas on further testing the power transformer?
This is the way it’s done. Give it a try. Your problem will become apparent.
Did you tape off your secondaries when you disconnected them? Is you power switch wired in series with the PT primaries?
ok,
i put the light bulb in and it lights dim when i power it up.
i am able to confirm that the transformer is putting the proper amount of power out of all of the lines.
can anyone confirm that the next step would be pulling and replacing the power caps?
If the bulb lights like a flash in the first few milliseconds and stay off the remaining of the time, then, the caps and the PSU appears to be no responsible of the fault. Try putting the tubes in the sockets again, but disconnecting B+ from PSU to the amp itself. And re-try the powering on.
Re-thinking in the problem, perhaps the kit is OK and the fuse you are using is too fast for tube amps or too small in its current rating. Can send us a photo or a schematic of the kit?
I'm currently traveling and will be away from my lab until Dec 31, so I can't try a transformer and a light bulb to see if dim is normal. What wattage bulb did you use?
If you are measuring this on the transformer alone, and not the board, no this isn't right. The board does have a 10K resistor from the 6.3 volt input to ground, so this is normal for a transformer connected to the board.
The transformer, switch and fuseholder blew the fuse without any connection to the board? The same setup makes the bulb glow dim while putting out all the proper voltages? If so, I would double check that the fuses are indeed the correct fuse for the SSE. I use a 2 amp slow blow fuse in the USA, and recommend a 1 amp slow blow for users in 230 / 240 volt countries.
If the transformer alone makes the bulb glow dim, try reconnecting the secondaries back to the board one at a time, with no tubes installed, and rechecking the glow. Start with the 6.3 volt, then the 5 volt, then the HV winding. None of these should change the bulb glow.
If all pass, then use a 60 or 75 watt bulb and install the rectifier tube. On power up the bulb should light up at about half brightness, get slightly dimmer within a second or two, then begin to get brighter as the B+ voltage comes up. Once the caps have charged the bulb should grow dimmer, back to near it's initial brightness, since there should only be about 12 watts of power being drawn by the board without tubes.
its a 100 watt bulb. its dimly lit with no tubes in it, and the transformer connected to the board
with all the tubes in it, it settles down to what looks to be a 30-40 watt bulb brightness.
thanks for your assistance.
Which material is made the fuse holder of? Sometimes Bakelite becomes carbonized and then, conductive. Perhaps it is the same fuse holder that is blowing the fuse.
i've completely bypassed everything besides the main power switch.
so currently the mains go into the power switch, which goes to the transformer.
OK, then discard fuse holder ;-)
Now, putting again tubes in their sockets, and with +B removed from the rectifier to the amp, what happen? (With the bright of the series lamp?)
so i decided to tempt fate, and just plugged it right in, with all tubes plugged in. it has no sound out the speakers.
all the heater voltages look good, the transformer voltage looks good, but im not getting any DC out of the rectifier.
additionally when testing based off this thread
https://www.diyaudio.com/forums/tubelab/158719-simple-se-checkout-dummies.html#post2051548
ground to R4 is getting low/no voltage at all.
based on this, i ordered another rectifier tube.
got the new rectifier in.
i left all the fuse stuff bypassed, and no light bulb, and i powered it up.
i managed to check a few things and saw 502 volts out of the rectifier. i let it play music for awhile (cant tell if it was any good as i am using a pair of speakers i've never heard before)
and powered it off. put it back through the fuse and first time i powered up it popped the fuse.
so one thing seems to be resolved but i still do have something amiss in there.
Take a good picture of the fuses you are using and post it here. There is a chance that they are it.
i dont have any fresh ones left, only blown.
they are 5x20mm slow blow 250/2 amp, and they have the little solder blob in them like these
do you suggest i go up in amperage, or perhaps try these instead,
Fuses
The blob in the wire is supposed to dissipate fast current transients, and make the "slow blow", but or they are failed or you need to migrate to a little bigger value, say, 4Amper.
- More Vendors...
- Tubelab
- tubelab SSE popping fuses with no tubes installed
