Hello,
Last year I built this amp:
http://www.diyaudio.com/forums/tube...8-build-abdellah-diyaudioprojects-design.html
It has been one of my favorites. I have all the parts to build another one but this time I would like to add a regulated (tube) power supply. I have never used regulated supplies on any of my previous builds but have heard praises sang about the benefits of regulated supplies.
I was hoping someone might have a fairly simple, easy to construct design that I could implement in place of the unregulated supply for this design.
I want to use all tubes as I have a lot of real-estate on my chassis.
Thanks for your help in advance.
Jeff
Jeff
steve bench's series of articles on tubed regulators, although you've probably been there already...
The TCJ issue archives from may 1999 to august 1999 at John Broskie's Guide to Tube Circuit Analysis & Design
Ok,
Thanks for the great links. I have read all the info there, I think I have a good understanding of how these different topologies work. Problem is I don't think I am savvy enough to create my own design "de novo". What I am really asking for is a "drop in" regulator circuit/schematic with all the component values figured out for the amp at hand.
Second best would be a schematic close enough that has adjustable features I could "dial in" the proper voltage. Can anyone supply me with a schematic I could use like this on this amp? I already have an identical amp built without the regulated supply. I could build the circuit on a proto board and splice it into my existing amp for test and tweak purposes. Once refined I could build another amp with this circuit installed.
Jeff
Jeff
