Yeah, I meant the feedback circuit from the o/p trans. Simply disconnect. This is best done if you triode strap the el84s, as no-feedback UL operation is likely to produce too much distortion. And the downside of triode mode is, of course, loss of power and theis brings into play factors such as speaker efficiency, room size etc. This wasn't a problem for me. In fact I use the amp with just four el84s (one p/p pair per channel). This reduces power to about 7W, but it does mean you can use better valves for the money. As it happens, the Unisys was my first valve amplifier, bought with Insurance money. Having since got into the technical side, it's pretty obvious that the Unisys is designed as a kind of valve/transistor compromise, and a lot of money goes into build quality (for the export market apparently). Component quality is nothing special. Everything I've done has got the sound back to a more trad valve sound. I much prefer it now, but if I had to start again I'd probably sell it and buy something else or build from scratch.
