Tube Square-Law, what and how to set up?
What is square law in tube amp/pre amp stage?
How can we get range/region of square law for some known valves, e.g. 5687, 7119, 6072, 12AU7 etc? I can not determine this in the datasheet/load curve.
And what is the effect on sound signature, distortion etc?
Thanks,
Ervin L
the only ^2 law I have come across involves the rate at which $ get spent.
COme to think of it, its actually logarithmic...
Yes I think it is logarithmic, with odd peaks of noise usually centred around hi-fi shows or DIY articles. Quite a controversial issue with wives and girlfriends too sometimes.
Also in general valve stuff at shows tends to be about 5-10x more expensive than solid state, and as a rule the more you regress technology toward the 50's (transformers, tubes, paper cones, alnico etc) and the less components used the more the price increases too.
Some valves, such as ECC82/12AU7, do have a part of their gm characteristic which is a reasonable approximation to square-law. EC90/6C4 too (=half an ECC82), which is why it is used as an RF mixer.
Look on the data sheet for a plot of transconductance versus grid voltage (not all sheets have this). Pick a bias point where this is roughly a straight line. Use a very low anode load resistor - much smaller than usual, as you want to avoid any linearising feedback from the anode voltage.
Schade claimed it so for RCA 6L6 at the very least.
Total idiot's speculation here, no facts involved:
I suspect its carefully shaped remote cutoff of Gm?
May or may not be square in the larger sense, but
only what happens in AB crossing really matters.
I don't know how faithfully this feature is copied in
off-RCA-brand clones?
Browse this page: Tube Data
Then find RCA "Beam Power Tubes" By OHSchade 1938
See Page 168 of the original document, or page 38 of PDF.
For tube without square law, you can reshape Gm
(reduction by NFB) by placing a square law diode
under the cathode.
A stack of Schottky diodes, FET or small MOSFET
that has been strapped as a diode. These have
square law function. But you need make sure the
square law diode function is scaled appropriately
for your quiescent current. A diode too big won't
curve the signal enough to matter.
I like Schottky, no recovery glitch as it turns on/off.
See Post#97 this thread:
http://www.diyaudio.com/forums/tube...mendations-10w-ch-version-10.html#post2275023
