Ideal I'd say.. 😛 Certain high transconductance triodes configured in SRPP might be good for driving a 75 ohm line as well since this topology saw use for video line driving as well. VHC family cmos logic is so much easier, and undoubtedly would work better without the complication.. lol
Ayon has made a Network Transport (a network music player) with "Vacuum-tube buffered digital output stage". The data sheet says "6H14 tube (digital output - signal buffer)" Network-Transport : Ayon AudioWell there we go, then! A 6CH6 is indeed designed for 75 ohm video lines. Perfect for SPDIF. 🙂
Is this SPDIF design really bad ? 🙂
(the Ayon CD-T is using also 6H14, but that's not important for me... 🙂 http://www.ayonaudio.com/products/cd-player-dac/cd-player/cd-t.html)
See posts 15 and 17. Yes, it will probably work since digital signals are quite robust and can function even through ideas as technically stupid as theirs.
hello, i did lampizator scheme tube output, and ques whtat😉 it sounds better that original spdif output, tryied on philips cd player.
sound is faster, more alive, energetic... totaly recomendet mod... at the same time no digital sound, its more like good vinyl player.
I bought and use one of these to connect the computer to the audio system. I like it a lot. 24bit/192KHz TUBE DAC DIY KIT - Lampucera1.0 + Lampizator CS8416 + CS4397 | eBay
Expectation bias is a powerful thing, even when you are aware of expectation bias. It is much more powerful when you deny it.
nope, im profesional electronic specialist. i measured diferences on both spidif outputs.rise times, overshoots and etc.
original has about 8ns rise time , tube out has only 4.5ns, tubehas more ringing on flat ,but thats not important, becouse dac reads only "rise,drop" fronts of signal.
On MCU originaly was also 4.5ns rise time. sooo.... ? tube is like speed of light ....😀
Rise time which is too fast can increase cable-related jitter.
do not agree, please study spdif protocol more closely, the faster signal rise, the less jitter is generated.plus dac is no more "quesing " it was 0 or 1,so data decoder is disbaling "data correction" algorithm
And ofcourse bad cable is bad in all situations, lets asume its good cable is used😉
This assumes that the faster risetime is preserved throught the signal chain.
Unless the cable is correctly matched and terminated with a correct load impedance (or source impedance if serially terminated), if the driver risetime is too fast, then ringing will occur at the receiver end, and maybe at the driver. That ringing at the receiver could cause further timing errors which defeat the original objective of trying to ensure accurate timing.
The problem is that many people think of S/PDIF as a solely digital signal. In the final analysis, digital signals still obey the laws of physiscs, and they dictate that signals with fast risetimes need correct handling to preserve timing details and to avoid overshoot / ringing if they are significant to the application.
No data correction takes place after SPDIF, so nothing to 'disable'. All you get is parity, so you either use or discard the data. An SPDIF implementation would have to be very bad to corrupt the data so badly that it fails the parity check.Lowrideris said:do not agree, please study spdif protocol more closely, the faster signal rise, the less jitter is generated.plus dac is no more "quesing " it was 0 or 1,so data decoder is disbaling "data correction" algorithm
Too fast slew rate can give rise to greater cable-related jitter, as I said. The details depend on things like cable length and how resistive the termination is at all frequencies. Basically, if you put a faster slew rate in then you must hope that the terminations remain correct up to higher frequencies. Obviously too low a slew rate causes trouble for the receiver data slicer.
- Tubes / Valves
- Tube SPDIF output
