Can anyone share their KiCad tube socket footprints with me please?
Not too difficult to create my own but I'm sure others have done it.
Thanks!
Thanks!
Problem solved!
As is often the way, after spending hour scouring the internet and posting a message in the software forum I came across this post from Pete Millett.
Then I discovered the "Create Circular Array" function in KiCad. A bit of trigonometry to work out where to put the first pad and that function did the rest.
Componentsearchengine
Hi! You can actually find quite nice components layouts for the belkin tube sockets on componentsearchengine.com . For downloading you need to register but that is for free. If you need layouts you can also request them to be built and within 1-2 days you get them normally.
I think they had layouts for the belkin vt9-pt socket - should be a standard noval-9.
Hope that helps
Cheers mike
Hope that helps
Cheers mike
Mine are in the zipped KiCad archive attached to this post:
https://www.diyaudio.com/forums/dig...c-linear-audio-volume-13-a-9.html#post5856267
There is a footprint for a noval socket and one for seven-pin miniature sockets (for an 85A2, for example). I've made the holes rather large so many types of socket fit in.
