tube rectifier life expectancy
My AZ1 rectifier seems to have failed. I a little suprised as it was being run at specified parameters. I've only been using this tube for about a year, and even then, the cd player was not on all the time.....
I've checked connections to the heater supply and these seem fine, the filaments however won't heat up, so I assume that it's done...
So have I just been unlucky, or should it have lasted longer....
thanks
Raja
AZ1 is a rugged rectifier with max 60uF at 2x300V and 2x60 ohms.
It should have lasted a lifetime in that circuit. My guess is a "monday" specimen of the tube with either a poor weld or poor vacuum.
Check the solderings on its pins, could be an intermittent contact. The socket could also be a problem.
Your guess is correct, there is no vacuum, the base for the tube has rusted, there is at least one hole, clearly visible to the eye. I won't be buying another from this particular supplier.
Raja
The circuit is very very good, best cd sound I've heard, I run mine without the rolloff caps or input resistors....
In a way having this up and running has kept me away from vinyl, I am looking at getting a turntable, but I question whether it'll sound any better unless I spend some serious cash. Turntable wise I've looked at the garrard 301/401 or linn lp12. Both seem to pop up every now and again, but are also steeped in controversy.......
Can you reccommend any good phono stage circuits, looking for a minimalistic approach.........
Raja
I didn't actually design the circuit, for that we can credit occasional user ultranalog, if it's specs and noise figures you're interested in, there was a whole series of information presented on tnt audio a few months ago, using the cap between these pins helps to reduce noise, do a search on the website of tnt, sift thru the article, this should give you the info you desire...........
Raja
