Tube PSU leveling Caps
I am planning to build and LCLC PSU filter for a tube PSE amplifier, and I am debated on 'how good' capacitors I should use in each position to achieve the best sonic performance.
My though process:
C2 is connected directly to the anodes, so the current across it is characterized by large/steep swings and the same frequency of the audio signal, hence I want a high performance capacitor in that position: most likely a high grade electrolytic capacitor in parallel to a film one.
On the other end, C1 current swing frequency is limited by L1/L2, hence my deduction is that any decent capacitor should be good in that position.
Any opinions?
From my insatiable urge to muck around all caps will have influence, ironically sometimes cheap caps can sound better can't explain why. What I can recommend hands down is to use a 0.1 to 0.47 uf Mundorf Supreme cap as the first C so it becomes a clclc instead. Why cause the sound of this cap is very very good & it's not expensive given its small value. You can give it a try after you build your Lclc supply.
Besides the small value will not upset the design of your psu.
