Would specs like these be appropriate for a pa-150 lm3886 amplifier? The input sources I have been using don't allow my amp to play too loud, so i figure i need a preamp. Would specs like these be appropriate for preamplifing a PS1 and iPod?
Input Sensitivity:50mV
Input Impedance: 100KOhm
Out-Put Impedance:12~600 Ohm
Dynamic range: 84.6dBA((300 ohm) 89.8dBA(33 ohm)
Gain:20dB
Frequency response:10Hz-60KHz +/- 0.25dB
Minimum THD: 0.016%(300 ohm) 0.45%(13 ohm)
Signal/Noise Ratio >92dB
Gain:20dB
